Ok so here's the set-up:
61mm turbo
lex/550s
walboro FP & AFPR (30psi with vac at idle)
WB
safc
running 1.2 bar on 100 octane fuel.
newer motor with forged internals
I'm trying to get to the low 11s A/F ratio and it's still pig rich (low 10s), in fact if I keep it on the floor it moves its way into the 9s.
Before I get flamed here I tried searching and didn't seem to find what I was looking for.
I had a couple thoughts and maybe the community can direct me.
1) Should I lower FP some as the lex/550 setup seems to be wicked rich inherently? Maybe this will get me a bit leaner?
2) I hesitated to reduce the fuel with the safc any further as I've read that reducing fuel at the various rpm levels by more than 15% would cause the ECU to alter timing (making it richer still?)
3) Screw the aftermarket screw (from reg reimer) in all the way in the lex AF body?
Any guidance would be cool by the usual 'mavens'
I'd rather not blow up another motor
thanks
Aaron
---------- Post added at 08:14 AM ---------- Previous post was at 08:04 AM ----------
while I'm at it here can anyone comment on how much boost is generally safe with 100 octane fuel?
20psi?
61mm turbo
lex/550s
WB
safc
thanks
Aaron
20psi?
