I had to dremel the shit out of the stock cluster, I didn't have to cut holes in the back, but I did in the bottom.
There's not tons of room, I really had to work that area for the vents to sit like stock, by the boost gauge. the bottom few mm is covered on the boost gauge too.
I'll get some pics of that if you'd like.
flubyux2 said:damn... im really curious to konw how much, or if any, material had to be removed for the rear of the cluster or from the bottom of the cluster. also, how much room there is between the boost guage area and the top of the ac vent.
you used the whole guages or did you end up modifying the gauges to fit properly?
