Finally blew my OEM HG. :-D
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
How long will it be down? Couple more hours...:rofl:
(nah, I need to order a cometic and ARP studs first.. go get the head cut probably.)
I just pulled the head off this morning, and it's ROUGH.... I shot some video of it, it'll be on my youtube channel in a few minutes.
Cyl #6 got it the worst... but most of the water jackets are pushed out. (That's how ya do it!)
Bounty: I was on the 60-trim for about 2 years, then the 66mm for 1 and now the 4088 for about, I'd say, 4-5 months? (not sure anymore.)
The music reminded me of Braveheart for some reason.............:biglaugh:
FREEEEEEEDOM!!!!!!!!!!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
That looks like about the same as what I did - 20+ PSI on a 60-1 CT, stock head gasket, ARPs to 75 foot pounds.
Killed it with detonation, same as you.
Bad news is, I also cracked three pistons... I suspect that detonation bad enough to push the gasket out that far is also more than the stock pistons can take.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Yeah, I just took the head off to see the gasket... the pretty much called it a day.
I should inspect the pistons too.
Might do that tonight.. I got nothing else to do.
Ali- I'll pm you.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
suprahero;890768 said:
Thanks for the link Steven.
Oops, sorry I missed that post:
this is mine.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
good show.
i blew my replaced stock head gasket in less then 4 weeks at 14psi on the stock turbo.
my deck was not flat though
i found that out after my mhg didn't seal.
my stocker had stretched a few ring's furhter then that,
i still ran those pistons for awhile..
i prolly lost it to detenation, i was at the strip hittin fuel cut and i had ran the stripp backing out of the throttle keeping it form hitting fuel cut.
i lost it about 3/4 down the 1/4 and lost almost all power since burning coolant...
MK3Brent
Very expensive....
Aug 1, 2005
2,878
CryoSlash;891839 said:
so eta on this build? Be cool like dave!
Well, looks like I'll be picking up some pistons in the next couple weeks... I just need to start accumulating parts.
I'll probably be done by May at the latest I'm supposing.
I guess I'll start a build thread once I get the stuff.
