This is so exciting...
Some of you know that I've been boosting the hell out of my engine for the past 4 years. 20psi CT26 (60-trim), 22-24psi (T-66), and now 30psi (GT4088).
Knowing I had pulled the pin on a ticking time bomb, I thought I better get it on the dyno to prove it's making 500+hp.
Tonight I hook up my air compressor to my boost leak tester, to go over some final changes in vacuum routing...
So I hear something..
I begin to laugh a little bit, and take the radiator cap off...
I take a look inside, annndddd.... **BUBBLEBUBBLEBUBBLEBUBBLE...** :rofl:
On a bright side, I found a couple boost leaks.
