Filter Minder
shaeff
Kurt is FTMFW x2!!!!
11
Around
That's very cool! I assume it works off vacuum produced when the filter is clogged?
You must be the one that outbid me for that on eBay JJ.............:3d_frown:
Just kidding. I've never seen one before.........:biglaugh:
jetjock;1486864 said:
Yeah, it measures the delta P between ambient and the area behind the filter. Works with any kind of filter. Since a filter's efficiency increases as it loads changing it early is dumb.
http://www.filterminder.com/
They also come in panel mount for people like IJ ;)
As Jay said you can often find them on Ebay for cheaper.
I don't run a panel ;)
The Filter switch would be perfect though that way I can display it on the dash!
No Aussie distributor... :(
jetjock
creepy-ass cracka
9,439
I think the switch only closes at the end point. Better to remote the indicating type because it shows incremental loading. Either way I'm sure one of the flock can solve your problem. If they don't let me know and I will...
SWD Fredester 3
675
baltimore maryland
Here is the one that comes with the TRD intake on the 5.7L Tundra:
