figured you guys might enjoy this... dyno results
mechanix0889
reynoldsburg ohio
Well guys i did a build thread a while ago over in the build and projects section heres what the car is.
Mkiii
2jz swap.
Stock block other than greddy pistons
stock headgasket.
arps head studs
tt head:
crower 272
supertech valve springs and retainers
1mm oversized valves.
port and polish.
Turbo system
gt4202r with a 1.15ar
full custom 4 inch down pipe
xspower manifold modified with 2 external wastegates.
tial 44mmx2
tial 50mm bov
fuel system.
a1000 pump
a1000 regulator
1000cc precision injectors
Aem v1
aem wideband.
the car is a blast to drive and lovin every minute of it
race gas was used q16 and tuning was done by me.
facility was the University of northwestern ohio dyno building in lima ohio for the open house event.
863hp and 662 ftlbs was done at 35psi.
video :
Dyno:
some pictures of the car.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
thats a sleeper would never think its a 800hp car...good work sick car..
---------- Post added at 07:18 AM ---------- Previous post was at 07:17 AM ----------
what kind of radiator is that because my buddy with his 2j mk3 has been looking for aftermarket radiator that will fit in his car..
I don't know what type of tires you're planning on running for traction, but if it's something other than mt streets let me know. I've been trying to find something that is water friendly and the et streets arent'.
Congrats on the numbers.
mechanix0889
reynoldsburg ohio
ehhh still searching im on 19s right now and i think thats my main issue... so im looking for some 18s ccw or 17s...
i am running hankook ventus v12 evo2 275/30/19
they spin at anything less than 130.
thanks for all the compliments its a sleeper thats my goal because i like to pick on the domestic bastards around here... :)
---------- Post added at 12:21 PM ---------- Previous post was at 12:19 PM ----------
its believe it or not a ebay special.... 150.00 it did fine and coolant temps have never went above 198 running a tt fan and clutch and mkiii shroud.
if you do the thick radiator you have to trim a 1/2 off the fan or else it flexs and wipes the radiator... it already happened once...fyi
