starscream5000 said:You could fab up one similar to IJ.'s design and only have to worry about the battery being moved. Just make sure you retain all the electronics that go on the stock manifold, mounted in a position where they are still functional (vacuum and water lines here), and you should be good to go.
Don't forget the throttle cable, you'll have to modify that to make it work with it's new location regarless of everything else.
Hey thanks a million man thats all i needed!jdub said:PM Sethron71...he lives in your neck of the woods now (Richmond iirc). He does nice work on a FFIM...made me one fully customized to my needs and retained the AC. He's a pretty busy guy, but might be able to help you out...don't expect this kind of work to be cheap
I posted some pics in this thread...you can see the alternator drop down bracket.
FFIM
This is IJ's build thread...there's a link to all his pics in his sig:
IJ's Build
