FFIM
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
aaaaahhhhhhhhh........ you guys are making me want a ffim!!!!!!! BLAH BLAH BLAH, i choose to ignore your advise....... dang...... im having some serious battles in my mind right now...... im planning on going a lot bigger than before, and i think my current intercooler core (18x6x3.5) might be too small for what i want now....... shoot. where did you guys get your pipes from for a ffim??? i know drift motion has them, but honestly, i don't like polished/chrome stuff.... thanks again
turbogate
Life is Boost
May 18, 2005
425
South, FL
To answer the original question:icon_bigg the only wiring involved as far as harness is extending the TPS wire to the throttle bodys new location. Keep in mind also that most FFI will require relocating the battery in the trunk, so the + cable has to be routed back to the front also and then distributed.
Guys, I cannot begin to explain to you what difference my RonR FFI (long runner) makes. Less lag, better overall throttle response. More air.etc At 19psi on my T04, I went from the -16 settings on my SAFC(stock intake) to having to bring that up in the -5 setting therefore bringing fuel cut back to life:icon_mad: I then had to settle to 17psi. Thats how much more air the engine was seing. I went from a pretty rich A/F at 19psi to being dangerously lean with the new set-up. The clean look and easier spark plugs access is just an extra bonus added. If I'm not mistaking, Duane was one of the few to have the chance to swap intakes and check the numbers, and He gained in the area of 30hp by just swapping the intake. Maybe that also included the bigger TB. I hope he will confirm this.
MRSUPRA
838
Maryland
Thanks for the info Turbogate. I haven't heard to many people comment on how the RonR. longrunner manifold performs. I just can't ditch my AC.
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
gixxer750 said:
I've got a couple of long runner FFIM's sitting around. planning on bringing them to tx to sell.
do the ffim's you have come with an alternater relocater???? how much you want for them???? pics??
