FFIM possibility poll
Which type of Front Facing INtake Manifold Would You Buy?
  • Steel short Runner
    Votes: 8 17.4%
  • Aluminum long runner
    Votes: 27 58.7%
  • Aluminum short runner
    Votes: 7 15.2%
  • Not interested
    Votes: 4 8.7%
  • Total voters
    46
Status
Not open for further replies.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
starscream5000 said:
Poop ;). I'm thinking it's a type of steel.... Not sure though, mine doesn't rust.
:rofl:
I would be interested in your FFIM with detailed pictures of the work.
Good luck with everything and don't be shocked if your hard work isn't quite worth $300 for a manifold. ;);) (Just a pre-warning).
-Jeff
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
funky_monkey58 said:
yes these will be flow tested :icon_bigg
i have no idea how a steel manifold is gonna flow compared to a ported aluminum manifold. But it shouldnt be too terribly far off.
:bigthumb: voted for aluminum long runner :D
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
If you're going to make short runners, I suggest getting your hands on one of Ron's alternator brackets and having it duplicated. It will be a must ;).
Or put the work into creating your own...
johnny_boy83
Louisiana
As frightening a thought as this sounds, I looked into converting a spare stock turbo mani into a FFIM and I found that not only was aluminum hella expensive to weld, but many alloys can't be welded, only cast or machined. With that in mind many places use a composite process by which an epoxy or other strong adhesive is used to bond the aluminum together where cost is important and shear strength isn't as large an issue. Radiator repair shops use an adhesive compound to seal radiators that religiously hold 16psi and i had a shop seal an AC condenser and the lowest pressure an AC system sees is roughly psi= ambient temp in degrees farenheight. This brought me to GLUING a FFIM together. I never had the sheer balls but i considered it seriously for a time. I just couldn't put the work into testing. The thought of a FFIM made of aluminum tube and JB Weld made me smile though :icon_bigg
PS- I had thought of steel but I thought the aluminum lower mani would expand at too different a rate than the steel upper mani and under boost I'd blow the manifold gasket....it won't take the torque an alum head/iron block will
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
The entire manifold upper and lower will be replaced with my steel unit. I thought if this same concept and then also thought of the differences in flow between a mandrel bent pipe and the cast aluminum lower.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
oh wow this is intresting why the hell whould u use steel for ffi that just plain dumb to much work
alloy alot easyer to work with cetp you need mighty welder to do thick stuff
stick to aulim is just far better and way easyer to work with
ps pic's or msn paint skills come in handy or even cad drawing
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Well I have been building them for quite awhile now. You will be amazed at the work. I am working on some methods of stream lining the process for better mass producing to cut costs but I think $525 shipped in US for a Long Runner Custom w/ Alternator Drop down bracket is quite reasonable. But anyways good luck, I think you will find making the ports and working the steel painstakingly long work. But I may be suprised. Let me know if you need any help.
Thanks,
Seth
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
The reason for steel to be used is for cost.
Status
