FFIM PCV plumbing
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Dont worry about it. Just get your self a catch can, line coming from the accordian pipe to the top of the catch can. A line from each valve cover to the side of the catch can.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
black87turbo;1206070 said:
that was my concern....the Q45 TB does not have a port for the PCV.
Val, I run my PCV like Fletch said and I've had no problems with it. You can run it from cam cover to catch can to intake manifold which is what I've red is the proper way but double check me on that, jdub could give you all the info you need on this, send him a pm.
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
thanks man....
