FFIM noises?
5
dbsupra90 said:
yeah mine whistles at idle (throttle cracked open) and at low throttle/hi vac situations. 10 in/vac and boost it doesnt whistle.
larry at sp said the ford isc ports on the bottom might be causing the whistle. so might try to fill those in instead of using a block off plate later down the road.
here is mine btw-
http://cgi.ebay.com/ebaymotors/86-9...016QQitemZ260147368808QQrdZ1QQsspagenameZWDVW
you have a point there, as that would be much the same effect as blowing over the top of a coke bottle...
