Well here's an update. I have the ffim itself almost finished. I only need to get the TB flange welded onto the plenum, cap the end of the plenum, add the AIT sensorbung and add some vac connections.
As you can see i have also found a way to retain the stock cables and stock cruisecontrol. I just need to make a bracket to screw the original linkage onto the manifold. Works just perfect.
Now i have a little problem with my ffim that i'm not to fond of. But i think i'll just clamp it down, heat it up and see if i can get it back into shape again
See ? It's sagging about 4 - 5 mm. I don't like that...
