Im a few paces behind you, so I havent tried starting yet, but, before I do, Im going to make a long check list to go over before cranking... My biggest concern is making sure I have my Q45 wired properly... The rest of the wiring, IMO, is pretty cake... But that Q45 makes me nervous... However, there are several people using it now, so Im sure if I have an issue, I can find the solution...
Dude, one thing I would DEFINATELY check out is your CPS... 1st, make sure it is installed correctly at TDC, and 2nd, make sure you have NO loose or broken wires at the connection... I actually had to tow my supra home once because she died at a gas station... I looked all over that bay, and she just would NOT start... Then, finally, mad as hell, I threw a rag at her and it just happen to hit the CPS clip and a wire popped off... I pushed the wire back in, hmmmm, i wonder? Hoped in the car, turned the key, TAH DAH! Magic! The car started right up, no problem! Something THAT friggin simple killed my car and cost me a tow bill...
