FFIM for an auto
bis_1315m
197
charlotte north carolina
the people that get FFIM's without the isc how does there car idle. I mean how do they get air into the engine with the tb closed. and for the auto part of the ? where does the cable coming from the tranny go I've never seen it on these setups before someone please help I would love to have a ffim but my car is auto and I would love to get rid of the isc thanks
Michael
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
You could crack the throttle body open with the adjustment screw on the top of it...? Not really sure what you're talking about with the cable from the transmission, the speedo cable that goes through the firewall? You'll have to do more than just bolt one on too..
-Chris
He's talking about the "kick down" cable...it increases line pressure based on throttle plate position.
bis_1315m
197
Correct I'm talking about the kickdown cable sorry I forgot what it was called there for a moment. So if I wer to crack the tb with the adjustment screw you think it would be the right A/f mix thanks for the help though.
Yeah...just used the more more common name I've seen around here. Line pressure cable is the correct term.
Nice pulley IJ ;)
Doward
4,245
Alachua, FL
What is with people wanting to ditch the ISC lately? :3d_frown:
Ian, this might sound a little crazy, but you should build a coil cover that's level with the front timing cover... looks like it'd clear the coils you've got mounted on the valve covers - put some vents in it, and I think that'd be damn sexy on your motor!
bis_1315m
197
IJ. said:
We don't have a "kickdown cable" ......
It's a line pressure cable.
I just had a +240mm cable made and machined up a pully for the TB I use.
Hey I like your setup 1j is there anyway you could make another steup like that for me I've got money well I will have money do you have ot drop the tranny to switch out the cable or is it an extension thanks
dbsupra90
toonar
indiucky
if you unbolt the stock tranny cable and pull it out from behind the motor there is actually quite a bit of length to it.
one thing you have to be sure of is the cable is pulled full open when the throttle is full open.
here is mine. stock cable mounted on a custom tbody linkage.
bis_1315m
197
your setup looks pretty good to.
bis_1315m
197
Just curious but where is your isc
