Ferrari Failed Emission
Status
Not open for further replies.
LamaRossa
One and Only LamaRossa
Apr 6, 2005
131
ct
god damn Ferrari
yup failed today
now my question is
EGR i just did the test. started the car up took the vaccum hose and suck on it , car did not die that means its probably clog
anyone knows what part of the EGR valve is not working so i could take it apart and fix it save $100 instead of buying a new one?????????
failed co % 0.61 instead of 0.53 and PPM NOx 2388 instead of 1167 damn NOx
i def thinks its the egr any suggestion is appreciated
thanx
Lamarossa
LamaRossa
Apr 6, 2005
131
ct
jbsupra89t said:
Do you have cats on the car?
-J
Yes has 3" cat i just swap out my 02 sensor before this emission so maybe thats it and EGR is def stuck
thanx man
figgie
Twin Cities, Minnesot-ah
wellthat high a NOx is usually and indication that you are running lean or your timing is to retarded.
have you checked and triple checked your timing is set at 10 degree BTDC? Also did you warmt he car up at LEAST 30 minutes prior to going to get the test done?
LamaRossa
Apr 6, 2005
131
ct
hey yes i drove the shit out of it for like 35 min on the high way
my dump tube was capped
yup 10 deg. btdc
87 gas though
outofstep
Senior Member
fwb
3-4 gallons of (m)ethanol in a half full tank. Just about impossible to fail when you do that. Heh, I tried that method with 550s and swapped in a stock afm and fouled plugs just to see if it would pass (I didn't need to go any time soon). Yep, it passed.
figgie
yup 10 deg. btdc
87 gas though
still Nox is a good indicator of the combustion temprature. the higher the temp the more NOx is produced. Basically it is the exact opposite HC
here you go
http://www.firstfives.org/faq/smog/smog_faq.html
also outofstep is right
if you can find e-85 in your neck of the woods. Put some in the tank but DO NOT exceed 20%!!!!
also notice the relation of HC, CO and NOx in this PDF
http://www.autoshop101.com/forms/h56.pdf
you might have to FIND a way to lean the system up. At stioch the CO level is pretty damn low but the NOx are high but not at thier highest point.
Ckanderson
2,644
The beach
No way, you got a ferrari? You should take it to a Ferrari dealer, they can probibly fix it for you... Good luck!
LamaRossa
Apr 6, 2005
131
ct
here you go
hey thanx man those are great sites
i believe its my EGR took it apart today, clean it ,make sure every part work ,
installed it in the car and test it while its idling
i took off the vaccum hose going to top of EGR with vaccUM and the car still runs fine , car shoulda try to die
so EGR is fucked i gotta buy a new one
damn it
More money
Lamarossa
Turkish
188
I suggest you just do yourself, us and the world a favor and drive that ugly bastardised step child of a car you have there off a cliff, thanks.
americanjebus
Mr. Evergreen
wa.
im sorry to point this out, but are those blocks behind the tires in your sig??
im sorry man but thats not quite a ferrari. for one it weighs a good 2000% more than one.
sorcereur
MKIII Revolution Inc.
NC
No shit sherlock...
LamaRossa
Apr 6, 2005
131
ct
sometimes i just wonder were some of you are coming up with some of these replies ?????????????????????
wow ive learn so much shit about emission within the last two days im gonna start teaching a class for cheating emission hahahha
no shit its not a Ferrari.
Lamarossa
sorcereur
NC
If you unplug the egr vacuum hose, the car will just idle like shit and sound like a misfire..... At least that's what it did on my old car.
Status
