fast mods for the drag strip
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Usually when you upgrade your fuel injectors, AFM, and I highly recommend installing an adjustable fuel pressure regulator with this at the same time because a high flowing fuel pump can be the death of a tired +20 year old stock FPR.
Sorry, I don't know when the change occurs, but my guess would be past 75% throttle, or WOT, but I don't know for sure.
8,900
starscream5000;1161493 said:
Our fuel pumps do not run off of 12 volts at all times. When you install an aftermarket fuel pump, such as a Walbro, it needs the constant 12 volts to work properly an to it's full potential.
No it doesn't. It only needs enough voltage to supply the fuel needed to keep the air/fuel ratio at its proper point.
Running it on 9 volts when not under load will make the pump motor last longer.
brad horton
102
Alabama
another numbie question. whats my rear end ratio? Is it a lsd or open? Its a 1987 supra 7mgte auto. i read the tread on how to identify using the axle code but i dont have the car yet. Is there just a gear set that came with the turbo auto? if not does any one know the range of ratios they came with?
gaboonviper85
3,236
Northeast Philly
brad horton;1161670 said:
any clues on what they should run stock with a auto and cold air?
0 to 60 in 5 minuets flat...
To be honest, I think it's retarded to race a stock supra....it's not going to be impressive at all....especially a tired supra! Good luck in whatever you do (even if it's boring the hell out of people waiting for you to finally cross the 1/4 mile at 92 mph).
darkspeed
138
Montgomery, AL
www.pbase.com
I disagree, to a point. Get one or two baseline runs. Don't kill it, or load it up. Just run it out like you would hitting an entrance ramp of one of our lovely interstates.
This will give you something to gauge future mods by. BTW, if you delay our track time, we will shorten your life expectancy.:icon_bigg
brad horton
102
Alabama
haha i dont know if you have been to steel before but there usually really good about track clean up and want run if im worried about it
That looks like a nice start Brad. I'll make sure and keep you in mind when we have a local meet.
brad horton
102
Alabama
please do. Im hoping to have all little problems fixed soon around christmas and be ready for paint this summer. Even if my supra is not running ill come hang out with yall I might end up there in cougar or if nether is running ill all ways have my rsx.
zambini
464
Detroit, MI
is your accordian hose epoxied together? replacing that, and all those dry-rotted (probly cracked) hoses around there is gonna make you really happy when you take the car out afterward.
looks like that car hasnt been air conditioned in a longgggg time haha.. all the rust in front of the engine is actually kind of a good sign- its not leaking oil everywhere.
brad horton
102
Alabama
if you look left on to profile info youll see the pipe that keeps blowing its a pvc pipe from the intercooler to the intake
