ValgeKotkas said:So you say engine undertray is SO important? I believe my car hasn't had an undertray in a decade at least
And your car is an NA which doesn't generate even close to the stock heat output of a GTE let alone a modded one......
starscream5000 said:More like the other way around
It protects the road from the grease and shit in the supra
Idealsupra said::biglaugh:
I for one do not have a fan shroud OR any of the undertray and have been that way for about 2-3 years. i have a fluidyne however.
personally i dont feel the undertray is that big of a deal cooling wise. shroud i could see making a decent difference though. obviously having both would be optimum but i dont think mandatory.
crisp said:Hmmmmmm..... someone needs to place temp. sensors in several strategic locations and perform a THERMAL DISIPATION ANALYSIS with the control being values WITH the lower tray... and then WITHOUT it...
(Could also try without the shroud... and without EITHER the shroud or tray, as well... just to see what the differentials would be, ay?)
-crisp
starscream5000 said:I nominate crisp for this job :biglaugh:
