Falling boost.....ideas on the cause of it?
suprafanatic
1,607
Greenwood, IN
for some reason the supra doesnt want to hold very much boost. right now it will boost up to 15 pounds and then drop to 10-12 pounds. at one point on the dyno it hit 15 then dropped to 7 pounds.. its a 60-1 turbo. any ideas what could cause this? i'v tighted up all the clamps on the IC piping..:1zhelp: iam also running open down pipe
subjug4tor
Man up, Nancy.
May 8, 2008
77
DFW, texas
I've heard of failing wastegates that caused similar problems, but I could be wrong. Seems to me that if it was coming open when it shouldn't it would cause boost to fall.
I would think that if it were a leak of some sort, It wouldn't want to build to full boost at all, rather than get there, then fall back down. Once again, I could be wrong, just my .02 cents
suprafanatic
1,607
Greenwood, IN
i have the 60-1 ct26 3in elbow and the megan racing down pipe that is supposidly 3in as well. and after that its wide open..lol another thing i was thinking about.. i have a cheap voodoo MBC would that maybe be leaking boost through to the wastegate causing it to open and letting boost out?
