Factory 7MGTE ignition timing figures?
BLACKCAT
185
BHG
Does anyone know the factory 7MGTE ignition timing figures at the various rpm/boost levels?
thanks
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
3p141592654;1771388 said:
Attached is an image of the timing map. Haven't figured out how to attach files to this post. I would not use this map without a very capable knock-sense algorithm monitoring things. The stock ECU knock sensor is fast and pulls timing a lot during normal operation.
^This is the latest data. I can tell you from experience that the ECU adds approximately 11* at around 5200 rpm's regardless of boost level.
