Sweaty, defeated, hungry, and tired ... but out of all of them very VERY defeated ...
I have a 89 7MGTE in an 86.5 Supra. As it stands, I can get the car to crank no problem. It does idle pretty high [1500-2000], but cranks no problem. When you rev it, it studders big time doesn't want to go past 3000. I connected the HKS FCON that came with the car [yes I know FCON is not the greatest and trust me if I had the money I would rather a WB 02 sensor and an SAFC at the least]. After hooking it up, it will roll over but won't start and it smells like its dumping too much fuel into the engine. I do have a GCC and its hooked up too.
The reason I hooked up the FCON with it running like that is because without it hooked up, there was no sensor to read boost. With the unit hooked up, I am able to use the sensor that came with the kit.
As far as the idle, I contacted previous owner and he noted to me that he might have forgotten the seal washer when he put the ISC back on [waiting for one to come in from the dealership]. And he also had removed the 3000 pipe. The vacuum hose coming off of the IAC is hooked to the intercooler piping. Isn't that wrong? Shouldn't it be hooked in by the AFM before the turbo? Without the FCON hooked up [it can't read turbo pressure] and it throwing extra air through the IAC wouldn't that cause it to not want to rev?
Also, without the FCON hooked up it cranks up fine yet with it hooked up it doesn't start ... any ideas?
Thank you guys forehand for your dedication to helping people and to the people that want to flame me sorry for my lack of knowledge I'm trying to learn.
