I've just started my build for the first time and it fired into life although the HKS external wastegate seems to be leaking exhaust gases at idle from the screamer pipe (quite loud) is this normal or have I fitted it wrong somehow?
I assumed the wastgate would stay shut until it was opened by the electronic boost controller, otherwise surely if it leaks at idle then the engine wont be able to build boost up
Help greatly appreciated
