Hey everyone, I have a question! I wanna run an external Aeromative fuel pump instead of just the 255 walbro fuel pump! Should I run a seperate resistor/relay setup on this or use the stock factory fuel pump wiring to complete this setup?
kwnate said:I ran a seperate relay for the A1000, the relay is triggered by the stock fuel pump wire. You run 12volts straight to the relay, ground the relay, then your 12volt connection to the pump and ground the pump itself. There is a wiring kit available for Aeromotive, I got mine from Summit.
Cool! Thanks guys for the help!dbsupra90 said:yep mine is setup the same way. altho we eliminated some of the stock system as well. i would recommend running 10g wire for the battery feed to the relay, and 10g from the relay to the pump.
