exhaust
bigaaron
4,692
Pomona, CA
www.driftmotion.com
If you had seen the quality of the Tanabe, you would not question why it costs what it does. If you had someone make a full stainless tig welded exhaust that is as clean and fits as good as the Tanabe, you would spend probably spend more. Their quality control is amazing, noticeably better then the RSR.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
And i've seen tanabe in person, it is beautiful, and sounds super nice at an idle.
i just priced 3.5'' exhaust stuff through summit racing, and you can build a 3.5'' system pretty DAMNNNNN CHEAP!!!!
Pipe
http://store.summitracing.com/partd...&N=700+4294787297+4294923429+115&autoview=sku
Bend kit
Get some muffler from whoever ya want, and for under 300-350 you have a 3.5'' exahust... and that'll out flow all of the exhaust you listed. haha
And if you cant weld, just leave some extra pipe and the exhaust shop would probably swedge(enlarge) the end so its a slip fit exhaust... or just get some of those clamps that hold two pipes together...
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
i always wondered....
dual 2'' pipes on each side...
like a V8 collector, and then 4 pipes off of it...
i dont like the idea of a 3'' pipe under the car, i want ground clearance...
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
i have stock ride height, i almost never scrape during normal driving conditions. it hasnt ever dragged on speed bumps or larger humps or driveways. oh, i just saw you live in cali, youd get hassled so much with my exhaust. its about as loud as it gets... louder than an open DP because the noise doesnt bounce around under the car.
iHartSupra
26
Duluth, MN
I run the Blitz. Haven't with the new engine setup but never scraped when the car was on the road.
The RX7 is another story. Every crack in the road feels like a kick in the balls.
