Exhaust systems
grimace65
31
so cal
is there a difference between a greddy (namebrand) exhaust system and a muffler shop that gots pipes with the same size?
DrakeMK3
"The Duck"
Knoxville, TN
The muffler shop will probably crush bend the pipe, whereas, the greddy, hks, apexi, etc. systems are all mandrel bent and yeild more power.
mkIIIman089
Ohio
Yes. The name brand will be of much higher quality I believe. They will use mandrel instead of crush bends (in most situations I don't think exhaust shops have mandrel benders) and you might not get the sound out of the system you buy and have built at the exhaust shop. It is much cheaper IIRC, but I think that the name brand exhausts are worth the extra cash.
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
if one is worried about crush or manderal bend.. just call the exhaust shop!
since i have moved, i have located a very reputable shop in Bistol Va, w/a mandural bender able to do 2.5, 3 & 4" exhaust!
whitemk3
east TN
Were is this shop at i live in johnson city .
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
state street.. named benny's.. pm me.. im looking for some supra peole in the area.. i just moved to bristol! (trying to get my MKIII here too)
ok just called them, no mandural bender, just a normal bender (dosnt place kinks in the pipe) there # is 276-466-5001
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
Mostly sound.
A good aftermarket exhaust system will be tuned to cancel out resonations caused by the engines, and will have a resonator as well as a muffler.
Most custom exhaust setups don't use a resonator, and end up causing spots in the RPM range with a lot of resonating frequencies... doesn't sound too good, and gets annoying real quick IMO.
Ckanderson
2,644
The beach
Thier is a difference, both in quality and sound. A aftermarket system (expecialy really good ones [Supersprint]) is designed for that car, with that engine. If it is properly designed, thier will be no resonances, and it will fit perfect. I have had custom exhausts on car's before, and they cant hold a flame to the way a good high quality exhaust sounds.
