JustAnotherVictim
Having upgraded one and the other I feel the cat back more.
Doesn't kick in as quick but the pull feels harder.
CRE said:Much higher displacement. I know it's not double that of ours, but aren't their exhaust systems also shorter? Hence less cooling of exhaust gases in transit.
I'm not convinced that 2.5" is the biggest you could go on an N/A before loosing performance. Our stock resonators and mufflers are baffled and restrictive, the piping is crushbent and has 90º bends... with these facts in mind a smaller diameter is needed to prevent the exhaust from cooling too much before it exits the system. I rather doubt that an unrestricted exhaust system (high flow cat, straight through resonator and muffler) running as straight as possible couldn't be built with larger piping. Minimal restrictions and a good header (AFAIK - this is where the scavenging is the most important/helpful) you could most likely build a 3" N/A exhaust and see a benefit.... the question is if it's worth the trouble for such a small gain.
