i found a little more information on it,
http://www.supraforums.com/forum/sh...are-GReddy-7MGTE-Under-Hung-T4-Turbo-Manifold
it does look like a rare piece at least, made by greddy before they went to trust, and one person mentioned that he's only seen about 4 in the US
so I guess this is where i'm going with this, i have a crappy ebay manifold, the T4 flange is warped, and it looks like i need a 1" spacer, we were just going to weld a spacer on it and fix that problem,with that the down pipe will need to be extended. Current setup is a master power t-70 and a tial f41 wg. The compressor housing also rides the pipe if its clocked at the 6 o'clock position, i have to turn it to about the 7-7:30 position, 8 hits the frame, Otherwise it gets ran at the 2 position and does a swift 180 at the valve covers like so, but at that point then your fan except it would be going striaght to the pipe closer to the fender "because of the FFIM"
i've been out of the scene for a while so i dont know if some new magical fabricator has came out with some fantastic work to make mild sized turbo's fit easier
I'm also looking for a FFIM last person i knew that was making them was Ron R. but sounds like you have to rip and pull his arms to do it anymore
IC pipeing is also being my issue, but if I recall my original plan was Run the turbo side along the top of the frame like Ian did before his ..LS.. swap
And it looks like a Electric fan might be in store to, are there any that mount up to the koyo? I dont have a stock shroud thats why i ask
The only reason i was looking at this was 1 its a work of art, 2 it give you tons of space below at least "for IC pipes.
