Well my road race car during the last race last year started to put some oil into the intercooler. i assumed it was from the ct26 not being able to handle my high oil pressures on start up without a restrictor. this year to confirm i installed a turbo feed restrictor. as well as i plumbed in a spin type parker filter, the same one adjuster uses, inline with the hose from the accordian tube to the metal line that ties into the valve covers. figuring if the restrictor didnt fix the problem i at least could rule out the turbo if the catch can took in alot of oil.
this puts us to the current situation. my first race was last weekend. after my first 20 minutes of driving after coming back in the pits the catch can was filled. here is a picture of the amount of oil present. Ignore the oil color thats a long story.
it did this every run. if im not mistaken this means that i have excessive blow by. so in order to confirm this i did some compression tests and leak down tests today and this is where it gets interesting.
Results
Gauge A
Cyl 1 150
2 150
3 152
4 155
5 150
6 150
Gauge B (crappy harbor freight gauge messed up therefore some missing results)
Cyl 1 151
2 145
3 155
4 140 (most likely did not crank engine enough)
5 no results didnt crank long enough
6 150
i gave up on the harbor freight gauge so dont worry about it.
here are the leak down results
1 8%
2 8-9%
3 11%
4 13%
5 17-20%
6 8-9%
the leak down test was ran with the cylinders on their compression stroke about three quarters of the way up
The engine is a 7mge bottom end rebuilt by yours truely two years ago. it has 2 seasons of autocross on it, and one season of road racing. the engine is completly stock running on 10psi of boost with a wideband and no safc or anything since i am just hovering below fuel cut. the base timing is set around 7-8 degrees due to the high compression, and the car is always ran on 93.
1st question. should i rerun the leak down test with the cylinders at the top of the compression stroke? reason i ask is it seemed like when i repeated the measurements there could be quite a bit of variation depending on the piston positions.
2. these results, at least to me, show nothing really conclusive as far as a single cylinder being down, does that seem right?
3. what can i do to determine which cylinder has a bad ring?
anyone have some ideas.
Results
Gauge A
Cyl 1 150
2 150
3 152
4 155
5 150
6 150
Cyl 1 151
2 145
3 155
6 150
1 8%
2 8-9%
3 11%
4 13%
5 17-20%
6 8-9%
