Engine wont separate from bell housing please help
917mgte
115
butte mt
In the process of doing an engine swap and i have everything disconnected from the engine and all the bell housing bolts out but the engine wont come apart from the bell housing help!!!!!!!!
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
87M-GTE;1522835 said:
Hit it with a rubber mallet
... don't hit it there is a reason, either, pop off the c-clip on the clutch fork and pull the shaft that holds it out, or disconnect the pressure plate from the flywheel.
frax
57
los alamos
I had the same problem, listen to what has been said: Pull the pressure plate bolts or release the clutch fork.
Spent hours trying to figure out WTF was gong on before realizing what was wrong
5
No, just PULL on the fork.
