Yeah, my harness is pretty aged. It has almost no flex whatsoever. I took off the TB, and the part next to it, the IAC I believe to make it easier to get the harness out, rather than risk damageing it.I might get a new harness if I can find one, or worst case scenario, I'll make a new one. I'm thinking of making a connector at the firewall though so that the next time I have to pull the motor, I can just disconnect the harness at the firewall and save the trouble of disconnecting it in the car.
I also have a couple questions:
Acessories: Is it easier to pull the motor with the alternator and power steering pumps attached, or am I better off to remove them?
Transmission: I have seen two procedures, both in different manuals, one says to pull the engine and trans out together, the other says to leave it in. Which way would be easier? I don't have a lift though, so I have to go out the top though, so keep that in mind.
Thanks for your time and help, and I'll be sure to give a full write up and pics when this is done so I can help others that run into the problems I have along the way.
-AM3
