engine stand bolt hell :(
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I had the same issue years ago when I went looking for bolts to mount up my engine. I needed exactly as you said, 100mm long, I think they're actually 120mm, well anyhow, long story short: I had a machine shop make me some. They made 6 studs for me out of drill bit grade hardened steel for like $25 IIRC... they made 6 because they had the extra material and only charged me for 4. I've had several engines up on this one stand and zero issues.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Wow you seriously had custom bolts made for your engine stand? I cant believe its this hard for all of you to find these, im glad my local hardware store had plenty of different lengths in the same diameter and thread pitch.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Where are you in ontario? I got mine at Ottawa Fasteners in Nepean, Ottawa. I walked in, bought the bolts, and put the block on the stand. Grade 12 or something. They were mighty bolts!
eric
johnd
278
Ont. CA.
orderd mine at fastenal here in leamington, took 2 days to come in.
did you say your from windsor?
becauseican
Vancouver
www.bicperformance.com
Like said above depending on the type of stand you can use the factory trans bolts or the head bolts for the top tow bolts just under the head. For the bottom bolts you can simply use a smaller diameter through bolt and a nut to hold it on the stand. 5/16" grade 5 will work.
As for the 1jz/ 2jz they use 12mmx 1.25 bolts. It looks like BIC needs to put togeather a engine stand bolt kit.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Try these guys, I'm sure they'll ship to you if you ask reeeeeaaaaalllllly nice:
Triad Fasteners & Industrial Products Inc. Contact this company
2025 41 Avenue
Calgary AB, T2E 6P2
Phone #: 403-287-3444
Fax #: 403-287-1008
Key contact: Ernie Rawlyck , Owner
Toll free #: 800-661-7142
Website: www.triadfastners.com
iso: ISO 9002:1994
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
eric
windsor ontario
yes i am from windsor! you are close. lol i honestly dont know anyone around here with a supra..
and ya i ordered mine from fastenal early this morning. they said it'll be here wednesday
gaboonviper85
3,236
Northeast Philly
Kevin;1504936 said:
windsor ontario
now you're learning! That's where I ordered mine from for the same purpose.
