engine stand bolt hell :(
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
so anyway i have a spare motor that i want to put up on my engine stand. but i cannot find the bolts anywhere in my stupid little city!
i know the size of the bolt is m10x1.25 and i need a length of atleast 100mm to thread about 1 inch into the engine ( i measured my stand and stuff)
i went to partsource, canadian tire, home depot, napa, home hardware, rona and none of them have it!!.. i called up Windsor Factory Supply which is a huge store that has a bunch of this kinda crap and they said they didnt have it either!! and that they dont stock it.. guy said "they usually have 1.5 ptich but no 1.25." soo i called up fastenal and they didnt have it.. but they said they could get it shipped it in 2 days.. then i asked if it was grade 8 and she said no its grade 5. i asked for grade 8 and she said "i'll have to look into it..because i am the only one in the office right now..so i'll give you a call back etc.."
edit: Do i neeedd to have grade 8? is grade 5 not enough?
anyway why the hell ear these bolts soo difficult :(
anyone have any other suggestions to look into?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
grade 5 was fine for me. i used them to hold onto the engine for well over two months with no ill effects. keep in mind the entire engine was loading the bolts for about four days (two to disassemble and two to assemble)
for reference, a 5/16 grade 5 bolt (8mm) will have a tensile/breaking strength of 6950 lbs for fine thread, grade 8 in same size is 8700 lbs.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
I got mine at Napa.. then again I know them and if I needed it then can order them too. If you go back maybe they will order them. Home Depot doesn't have anything for Metric items.
Kevin
Apr 20, 2009
865
i asked if they could order them.. they said no :( (dont forget im in canada.. soo its napa canada lol)
Tractor store. I got mine at the Kubota dealer.
couldnt find a location in my city
thanks. i figured i need grade 8 because thats what people were saying when i searched on here for the bolt size.
so i''ll look for grade 5 then.
btw thoase stores i listed above... i didnt even get to tell them i wanted a grade 8 and they still said no lol other then fastenal
SupraRon
595
Canada
Call Fastenal. That's where I got mine. They're grade 8, M10 x 1.25 (thread size) x 80mm (bolt length). It's a bit of a drive for you, but there are 2 stores in London.
Kevin
Apr 20, 2009
865
92TealSupra;1504237 said:
If I have to I will get you some, and ship them to you.
unless you can get it to me faster than wednesday morning at a price of around $1.50 per bolt and $8 shipping
then ya that would be great LOL (the above quote is what fastenal gave me for m10x1.25 100mm in length hex)
Kevin
Apr 20, 2009
865
there's 2 locations here in windsor and i called them already. and i need 100mm length because of my engine stand. they said they can get grade 5 m10x1.25 by wednesday afternoon. and i dont wanna wait for grade 8.. and i am definately not driving to london for 4 bolts LOL
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Can't the London store just ship them to you? : D Might be worth the wait, I am not sure if I have or can get 100mm, I can check in case I can, Sadly I here I don't measure things in ( Metric ) The U.S is pretty stupid. So I have to learn it myself more or less.
Kevin
Apr 20, 2009
865
doesnt have to be exactly 100mm. if its longer i can trow in washer etc.. i dont wanna deal with london people shipping to me when i have a location right here lol. i guess i'll stick with the grade 5 ones that i can get wednesday afternoon.
thanks guys
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
thanks guys
Sounds good. You'll be good with 5.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
If you cut the mounting tabs on your engine stand shorter you can use factory transmission bolts. I do this on every engine stand I buy.
Kevin
Apr 20, 2009
865
i dont have tranny bolts.. that was what i was looking for first :(
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
maybe you're confusing them with what you're asking.
there is no grade 8 metric.
grade 8.8 metric is roughly equivalent to imperial grade 5
grade 10.9 is equivalent to imperial grade 8
Kevin
Apr 20, 2009
865
no she knew what i was talking about. she said "8.8 is grade 5 etc."
like i said. i asked for the size first.. then mention the grade after
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Never had an issue with grade 5, its all ive used for 3 different engines now, have had a fully assembled one on the stand with those bolts for a month now.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
ok, contact an actual fastener supply business, not your local auto parts store. a fastener place can get you anything you need (except dichromate JIS plated bolts with captive washers, but thats a whole other issue)
Kevin
Apr 20, 2009
865
i did.. i called fastenal.. and had already ordered them
