88supraFAST1;1027371 said:
I though they did, then whats the new one's they just came out with.
OEM oil pumps are "high flow"... our oiling system is a High Flow Low pressure design... dont be fooled by the "high flow" oil pumps out there...
and here are the 77 bearings... i dont know why you said they dont make them, as i just ordered a set from titan which got them FROM clevite... lol
http://store.driftmotion.com/Static/Itemclevite77bearingset7m.php
Machine work:
Block - clean it, align hone with ARP main studs, bore cylinders with a torque plate, deck the head.
Head - clean it, disassemble and replace valve guides as needed, replace the valve stem seals, adjust shims. Helicoil exhaust studs to prevent future troubles (and lots of swearing)
crank - clean it, take out the oil plugs and clean those out too, either polish or cut .10/.10 (main and rods)
and balance the whole assembly too! DO NOT forget to do that...
My setup:
Clevite Bearings
Eagle Rods
Probe Pistons (.40 over)
ARP everything!
HKS 3mm head gasket (as i want lower CR)
shimmed my oil pump 5mm
titanmotorsports.com
driftmotion.com
jscspeed.com
those 3 are all good vendors!
