Engine oil mixed with coolant...
johnathan1
Supra =
Aug 19, 2005
5,056
how long has it been since the colant was changed, and the system flushed? May just be old coolant (kinda dirty), or maybe a previous owner mixed different color coolants (not flushing when switching from red to green)
Try flushing it out, and see what happens.:dunno:
Hopefully there is no oil in it, or it could mean :icon_evil: BHG !! Oh no!!
johnathan1
Supra =
Aug 19, 2005
5,056
First, flush the cooling system.
Second, the block test is a kit that you can rent from, say, Autozone or Kragen that sits on top of the radiator, and detects any exhaust gasses in the coolant, which would mean=BHG. This is definitely the easiest way to do it, but won't always tell you if you have a BHG, when I had my BHG, it didn't detect anything, and I didn't have the gurgling noises behind the dash.
The Compression/Leakdown test is probably best performed by a shop, if you are a noob but it basically involes pressurizing each cylinder through the spark plug hole, and measuring how much pressure each one will hold, greatky varying compression #'s will indicate eaither BHG or worn rings, but usually BHG. This test is definitely the most accurate method of BHG detection. Hope I helped.
supramad77
supramad
Feb 5, 2006
331
Dartmouth, Devon, UK
I just did a compression test on my mk2. I got the guage from a local motor factors for like £12.00. Real easy to do. BTW it passed so i must have worn out rad.
MKivSupra_Rob
INLINE6
Jan 22, 2006
288
Wpg
after having my car parked for 3 and a half months i found the dark brownish crap in myt coolant res too.. im a little scared.
