Engine Management. Place your votes.
jdub
Feb 10, 2006
10,730
Valley of the Sun
bigaaron said:
Yes, and I am going to make the harness myself.
I finally got the wideband and air temp sensors installed on my 7m with Stinger last night, and right now it's idling at 10 deg timing and 14.6:1 af. I'm going to try to get it over to the dyno tomorrow.
Outstanding!
This car is going to be my 1st chance to drive a 1J powered Supra...got a feeling I'm going to be impressed ;)
tissimo
Stock is boring :(
Melbourne, FL
4 Ignition outputs for sequential ignition timing.
4 injector drivers incorporating 4 to 1 current ratio for injector response and lower power consumption
so it can only run the injectors in batch and coils in waste fire? or am I missunderstood?
Turbo Drifter
534
Surrey, BC Canada
For only 400hp I would run a S-AFC and a BCC On my 1jz that set up with a tuned ECU and 550cc inj. I ran 550whp on my 1jz though a large single. That was right at the limit of alot of things with that.
I now have a 2jz single in my car running a AEM EMS and I love the ability to change timming and monitor all the operations of the engine. This is not the set up for some one with limited EFI knowlage. If you are to go that way you will need to find a good tuner (not some one that says they know how it works but some one that has a proven recored).
Good luck,
Jeremy
bigaaron
4,692
Pomona, CA
www.driftmotion.com
That is correct.
I do agree that for 400hp a standalone is not needed.
BigTree
Targa JZA70 FTW
Jan 6, 2007
175
Canada, BC
Ya but after I get to 400, I know I am going to want more and more and more......
Trying to prepare for the future. I want to do it once and do it right.
