how the hell do you get a new one in. my starter is in the way so i cant put the connector on. any tips???
88SupraMan said:how the hell do you get a new one in. my starter is in the way so i cant put the connector on. any tips???
I somewhat agree only on the grounds of redundancy (no pun intended). I don't see any benefit by grounding on both ends and one end grounded should be sufficient. What is a ground loop?drjonez said:just a reminder to NOT connect the shield to gnd @ both ends. in doing so you are creating a possible ground loop, making for more potential problems....
