Engine harness problems...
kmckiness
Saint Charles, IL
lagged said:
i think around 175 would be a fair price.
anything that needed to be replaced. if the insulation is damaged on any wires, that wire would be replaced. any plugs that were damaged, as long as i can source them would also be replaced. all soldering would be done by an EXPERIENCED person (me, ive been making repairs like this for a long time now) and all of the loom would be replaced by high quality automotive grade wire loom.
it would look like new from toyota.
you pay to ship it to me, and ill pay the shipping to get it back to you.
i could also beef up the knock sensor wiring since that code is a common problem, espcecially with older harnesses. i would include chassis ground straps for the sheilding. no more KS code! this would be for an additional 15 dollars.
I would definitely be interested in this with the additional strength knock sensor wiring. How long do you think a task like this would take?
I was hoping to get my car back up and running by August 1st so I can break in the motor fully before the Chicago 2006 August 10th meet.
Thanks,
Kevin
lagged
1991 1JZ
new rochelle
Thanks,
Kevin
i can have it finished in one day as long as there are no connecters that need to be replaced, or i have them on hand. i do have a few, but if i have to source them that could add to the time it takes to complete the harness.
you can safely assume that i will be shipping it back to you the next day from when i recieve it.
as for the body plugs and different year harnesses, my mistake. ive seen a few 89+ cars with late ecus with all the same body plugs.
i guess what ive seen is the exception and not the rule, in that respect.
lagged
1991 1JZ
new rochelle
Thanks,
Kevin
let me know what youd like to do. PM me and ill give you my mailing information and i can get started on this as soon as i recieve your harness.
kmckiness
Saint Charles, IL
I sent a PM. As soon as I get the mailing info I will ship it out tomorrow.
