not sure what to search for under forums, so here goes. first of all, i haven't been on here in a while, but finally got the rebuilt engine in and am in the stages of breaking it in for a 1000 miles. (thank you, thank you...bowing)
ok, i have a NA with an intake, header & straight pipes with a magnaflow can. runs & sounds great! The "fibrous" material that lines the underside of the hood was coming all apart years ago and i took it all down. There's obviously a purpose or it wouldn't have been engineered to be there from toyota. I don't have engine overheating issues at all, but everything under the hood after a drive always seems to be extremely hot. I'm a little concerned. How it important is that hood liner? Anybody running without it? should i replace it? are there aftermarket materials?
Also, with the intake hovering right over the header, i'm thinking of fabricating a heat shield to go over the header, not too close. aluminum ok? ideas?
thanks guys.
thanks guys.
