engine code 34
122578
just takes time
Dec 16, 2005
n.c.
has any one encountered the engine code (34). "The turbocharger pressure is abnormal" is what the code stands for. any suggestions?
Bishop92t
773
USA
www.ma70.com
Boost cut, basically an overboost code. You either have a boost controller/shim installed and you're running too much boost, or you have a boost leak.
supraguy31
626
Pembroke, NC
Shimmed Wastegate. Check you Turbo Actuator and see if you have any Washers behind it. If so, Remove them and reset your ECU.
Cheap way to get more Boost but it better to just buy a Boost controller and be done with it.
Robert
122578
just takes time
Dec 16, 2005
n.c.
i have an AEM boost controller on a upgraded CT-26 but it comes on when on the low settin of 10 PSI's.
