engine break-up at 29.99 psi ? (gt4578)
scott2298
15
florida
i put new copper ngk and car will only start under wop then have to work it to stay running but still dies. i tested the coil packs and they were all 0 ohm. the car ran perfect up to 29 psi now wont run at all?
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
this is very interesting. Ian when you have some time do you think you can help me with my problem. Thread Not firing right
Just about to head out to rebuild my Trans but I'll look in at lunch.
scott2298;1546390 said:
what is the ohm in the coil?
Sorry don't know the spec on those coils, I'd expect something around 8ohms, plug the multimeter in and switch the range till you get a reading that isn't 0 ;)
My autoranging fluke is a PITA at times...
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Really? Because they are both 7 heat range...
BCPR is just a different height. BKR's are ISO while BCPR are JIS and the BKR's are a few mm's shorter on the top than the BCPR..They're both copper, both 7 heat range.
WhtMa71;1547332 said:
The correct plugs for stock coils(I believe JZ coils are the same) are the BCPR7ES. Used to be 3330, now 6282.
The jz motors are suppose to run the 6282's? I haven't tried these yet, but I'm willing too if that's what I'm suppose to be running.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Actually, I'm not sure if the JZ motors have the same problem as the 7M's. If you have the center spark plug cover and BKR(4644) plugs, the plug wire wont seat all the way onto the plug and can cause arcing. The BCPR(6282) plugs are a few mm's taller so this isn't a problem.
I tried the 6282's this past weekend and they performed very well up to 28.5 psi with no spark blowout at all. I'm using the 1zzfe coils which helps a lot though. Thanks for the info.
