hvyman;1516047 said:........skimp and then blame the 7m and swap a jz. eh.
CyFi6;1516132 said:Generally a bearing is a bearing... it shouldn't be contacting your crankshaft anyways. As long as its a decent company with tolerance standards you should be fine. TaiHo, ACL, NDC, Clevite, generally all reputable companies. Never heard of any of them having repeated failures when installed properly. Not too sure what horsepower has to do with selecting a bearing though..
IJ.;1516280 said:A hell of a lot, more power = a bigger bang and a harder push on the piston,rod, bearing , Oil film and crank.....
King BiMetal bearings actually deform and splooge out the sides like silly putty in high HP engines, saw a motor at my crank shop that ran C77 rods and King Bimetals in the mains, Clevite's were perfect Kings were trashed.
Clevites for M engines are now "Mystery Boxes" and will contain what's available at the time.
