For failing the equipment portion, aren't they required to tell you EXACTLY what piece you are missing? It seems outrageous that they can simply tell you that you are missing a mysterious piece. :dunno:
Are you sure they didn't specify
FUEL injection? Maybe it was a mis-type by the technician. :dunno: air injection could be turbo, I suppose, but I've seen your motor and it looks perfectly stock. :dunno: Don't have an aftermarket BOV, do you?
Get ready for some math:
Toyota factory spec: Bore = 83mm, Stroke = 91mm
Displacement = Bore area*Stroke = ((8.3cm/2)^2*pi * 9.1cm) * 6 cylinders = 2954.19ml = 2.954L
Now bored 40 over = 40/1000 in =
1.016mm = 0.1016cm larger than stock bore.
Displacement = ((8.3+
0.1016cm)/2)^2*pi * 9.1cm * 6 cylinders = 3026.96ml = 3.027L
That's a difference of 3.027-2.954=
0.072L which is far less than the 0.2L that the machinist claimed. To achieve a displacement increase of 0.2L, I'm damn near positive you'd have to bore to the point that the cylinders would be overlapping each other. Stock motor is 3.0 though, so again the machinist must be mistaken on how to calculate displacement or he can't measure for shit.
Both of which are scary...
Not sure how chevy would incorporate a throttle body into displacement, seeing as how displacement is the volume of air swept out by one full cycle of the engine...
