noah89t;1178247 said:does anyone here use the emanage blue with a wideband hooked to it for tuning?
TheNewRed;1205137 said:Im prepping too. the only bad thing is, is that you cant use that feature, and the "optional Boost sensor" too. I guess ill cross that bridge when i get my new motor together, it seems like a really nice/convieniant idea, for when your datalogging. Just for refrence, im using a PLX SM-AFR, it seems like these products were made to be paired up.
suprastanger507mgte;1205143 said:That's kool. I am also using the e-anage blue with the PLX-SM-AFR.
The PLX gives off the analog signal that is needed to log using the Emanage Blue. Its a pretty simple hookup, but yeah it would have been nice to use the Boost sensor and not one or the other.
Greddy sells this harness, its only $25 on MOHDparts.com. This harness plugs into the "boost" port. When you select the "Data Analysis" window it should pop up in real time display with check marks on the side. You should see checkmarks for RPM, throttle Position, AFM signal(in hertz), ect... and when you have this optional harness conected, you should have something like "boost" or "A/F"s, and when you click the check beside that option, the program assigns it it's own colored line, that flows along with RPM signal and such, on a horizontal, real-time line graph. It connects to our PLX boxes through an optional output port, that is used to send information to piggybacks, and stand-alones.noah89t;1205856 said:can you explain how you connected the wideband to the emangae? what you lost, and what harness did you buy for the install?
i have the AEM uego wideband and my emanage and profec e-01 each use their own boost pressure sensor, but i know i could buy the cable that combines the two.
someone told me to hook the wideband to the profec, but i don't know how it would data log.
noah89t;1206306 said:what do you lose while using this harness? i'm guessing, pressure sensor for emanage.
are you using a profec e-01?
TheNewRed;1206393 said:Correct, the "boost" port is accupied when the A/F harness is plugged in, therefor the boost sensor is not an option inless you unplug the A/F harness.
And no im not using the profec. Do you tune through the E-01, or can you?
noah89t;1206657 said:so do you always keep your a/f harness plugged in, or only while data logging? is you always keep it plugged in, how does the emanage see boost, and does it need to?
Andre;1209047 said:I am feeding the a/f signal AND the boost sensor signal to run 22 psi of boost
TheNewRed;1209418 said:How are you doing this? You are saying you are using greddy part # 16401301
and the A/F harness at the same time?
Andre;1209568 said:Yes at the same time
