Eliminating the MAF
quicksilver
56
owensville mo
with the MAFT your still using AFM but its a GM hotwire type and can be used in a blow thru setup to be more efficent and its less restrictive to begin with. The only real ways to get rid if it all together is a PHR MAP ECU, HKS VPC, standalone set to speed density, or a turbo A ecu with wiring harness and sensors.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Err... this may just be semantics, but still...
MAF = Mass Air Flow
AFM = Air Flow Meter
MAF is not equal to AFM.
empera
Authorized Vendor
Philly.
wat cars do the GM maf's come off ? i'll hit up the junk yard and look for a few, for myself and to sell :)
jaydm16
76
Is it possible to get a 2.5 inch gm MAF so it is compatable with most regular intercooler pipe kits? Also does the BOV need to be pre-MAF or post-MAF to vent into the atmosphere for a blow thru?
rakkasan
Currahee!!
Fort Campbell, KY
jaydm16 said:
Is it possible to get a 2.5 inch gm MAF so it is compatable with most regular intercooler pipe kits? Also does the MAF need to be pre-MAF or post-MAF to vent into the atmosphere for a blow thru?
No, the MAFT translator doesn't have a setting for 2.5", only 3" and larger. they sell 2.5 - 3" couplers so you can use a 3" MAF with ease.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
There was a list of cars that used the GM MAF - it was freaking HUGE. I got mine for an Impala SS. As long as it uses the 3 wire connector and is 3" or bigger, I think it'll work fine.
You can buy an adapter from Full Throttle for the 5 wire sensors if you want, and it's not very expensive.
rakkasan
Currahee!!
Fort Campbell, KY
Pre Maft, that way the air released has been metered yet.
