electronics question
MmmBoost
DDS Performance
ok electronics gurus out there, heres my dillemma
ive added a shock sensor to my car in the spare tire well. it is the type that completes a ground connection whenever motion or shock is detected. keep in mind that it is usually for less than half a second that the sensor completes the ground for each bump of the sensor.
ive wired the sensor's ground into the normal trigger for the rear hatch to set off the factory alarm.
my problem is that the factory alarm has a small delay, slightly less than 1 second.
what type of circuit could i make to make it report ground to the alarm trigger for say, 2 seconds, any time that even a little blip is reported from the shock sensor?
isnms
United States of America
Oklahoma
i80.photobucket.com
You're planning on setting off the factory alarm when slightly bumped?
Do you have a sensitivity adjustment for your sensor?
I know, here, the wind can get up pretty good and set off the warning on my alarm. It just chirps a warning on a two stage alarm. More violent shock will set off full alarm.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Sensativity isn't his issue, it's the pulse length from the sensor to the factory alarm that's the problem.
There are a few ways to do it, a cmos 555 is easy and reliable.
CRE
Oct 24, 2005
3,485
Denver, CO
Gotcha... Hopefully he had enough foresight to get an adjustable shock sensor and plans to adjust the sensativity to prevent that. (If not he probably does now.) :biglaugh:
If inclined, he could add a second stage to the alarm sys. with a second 555 and a counter. :naughty:
MmmBoost
DDS Performance
yeah, the shock sensor is adjustable, and im gonna set it so that a moderate bump or motion will set it off, i dont care if someone accidentally coughs on it lol...
im finishing up the circuit i built with a 555, thanks enraged for the tip!!!
