on an external have a hose from the compressor housing port to the pressure/in side of the controller, then have a hose from the BOTTOM port of the wastegate to the other fitting of the controller, then if i were you get another hose and connect to the TOP port of the wastegate and have the other end open vented to atmosphere and hide it some where safe, mine is behind my abs control valve body
