If I ever find a deal on one of these bad boys, I'll pick one up.
http://www.innovativeturbo.com/cgi-bin/htmlos.cgi/00196.3.3277669087010900463
I'll try to find more info, there was an excellent review in Turbo magazine about it.
Up to nine stage programmable boost control.
0-60 psi target boost range for each stage (1 psi increments)
Five different ramp settings to control how fast boost is allowed to build.
Launch stage for drag racing.
Shift input for automatic stage selection for drag racing.
Front panel stage selection by driver for street or dirt use.
Readout of actual boost during boost control.
Two analog data recorder outputs - Actual boost level. Target boost level.
Two solenoid drive outputs - One increase boost output. One decrease boost output.
Can be used with single or dual port waste gate.
Uses electronic pressure sensor in manifold to monitor and control boost.
Will force waste gate to produce preset target boost level even with air density, load, or mechanical variations.
