I run a truboost. First thing I must point out is it will take a few tries to get it dialed in. Also, it programs by using a duty cycle, NOT psi. It does show boost in psi when running, but you program it via a duty cycle percentage. There are other settings too, like sensor type, which must be setup, spring pressure, and so on. Once it is all programmed though, it performs flawlessly. I just setup the scramble boost option and installed a switch to activate like the instructions stated. I have'nt had the nerve to hit the button yet though lol. There is some useful info on youtube if you find programming it a pain, or I will tell you my settings and you can bump up from there.
