electrical problem, no power in cabin, HELP
Status
Not open for further replies.
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
jdub said:
Ok...check the grounds from the battery to the block and chassis. There is also a set of grounds that attaches to the intake manifold outside on the #3 runner...make sure thes are clean and secure.
okie ill do that tonight when Dallas comes over if it doesn't rain:cry:
it gave a spark tho when we connected the ground chasis to the battery, if that helps you to give me more info...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Also check the Pos connection to the harness under the fuse box and the one to the starter just for grins ;)
againstdawall06
298
mo
well, when non of my interior lights worked(which i thought was the problem he was describing) it was my rheostat, which i jumped and now all my lights work great, i always had the dimmer switch set all the way up anyways. :icon_bigg
boost fiend
852
Rockford, Il
i had a issue like this once. (i have a hotwired starter, keep that in mind.)
running errnads and the radio and other interior lights wold cut in and out.
fiancee get in the car to go to work and nothing inside. no dome light, no radio, no fan, nothing. after i got off work i go to the car and start looking around and found that one of the lil wires on the pos side had broken. solder it back together and started right up with no issues.
and maybe im misunderstanding, but your testing the ground from the bat to the chasis and getting a spark? not a good sign.
run over every lil wire you can by the pos side of the battery and your gonna find your issue. ill bet dollar to dogunt.
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
why is that a bad sign??
but ne ways it sparked when i connected it to the battery thats what i meant...incase u misunderstood me.
yea were looking into find a fuse or something wrong with the positive wires, but not able to do it cuz of work and school and my friend dallas is busy as well so im trying to do it as fast as possible...
at least i got it on stands
thx for the info
Status
