electrical problem!! need help fast!!!
suprafanatic
1,607
Greenwood, IN
well i was re- wiring my boost gauge to a different location, in the process i was testing the bulb in the boost gauge, when i turn the dash lights on i guess two wires were touching and all lights went out for the gauge and dash gagues..... the two wires for the boost gauge are what touched.. the fuses are fine none blown... the 2 boost gauge wires are going to the dash dimmer.... any idea what i need to look for or fix?? melted wires touching? if so where do i look?
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
depends on what you tapped the boost gauge power/ground wires into. if you tied into the illumination circuit, that the fuse you blew.
if you tapped them into the guage power supply circuit, then you blew the instrument circuit fuse.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
oh, maybe you burned out the contacts in the rheostat of the dimmer itself...
is there anyone around that will let you unplug theirs to test yours, provided you disconnect those boost guage wires to prevent any more damages?
also, did you smell burning plastic/wax or see smoke when this went down? if not, your wires probalby are Not damaged.
suprafanatic
1,607
Greenwood, IN
ok never smelled anythinig, no smoke, i did unplug the boost wires,, pluged them in to another power source so the boost gague is working, but not the dash gauges
antman
632
TN
May not be the problem but sometimes a fuse can look good but not be. I like to test all my fuses in question with a multimeter.
hellraiser456
130
canada
you probably blew the Light control rheostat (the dimmer switch for the lights). The panel for it just pulls off...easy fix.
(i am assuming you blew the gauge lights)
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
I have a dimmer switch from a 87 Supra. I dont know where in Illinois you are but If you pick it up you can have it for free or if you pay for shipping
