:1zhelp:
hey all i'm in desperate help to diagnost what I F*()$) up when i tried to do the foglight rewire (following the 87-88 model). so i first started out by cutting and tapping wrong wire because i didn't realize i was reading the post 89 model foglight rewire (yeah i know). so reconnected them back to how they suppose to be originally. then i follow on the 87-88 model version to do the rewire.:: angry ::. just for reference this is the directions i used for the rewiring http://www.supramania.com/forums/showthread.php?t=99842&highlight=foglight+rewire everything seem straight forward, after i have firmly connected the wires that i supposed to (according to directions), no lights (disappointment). I did the typically thing, check for good ground, check for blown fuses and etc. no luck. i then gave up and decided to put all the original wires back to where they belong before the foglight rewire since i don't care about the fog light anymore. but god's messing around with me, after i reconnected all the wire back ( i must've shorted something) my window doesn't work, my dash light doesnt work, and my heater control doesn't work anymore). checked all the fuses again...nothing blew...but one fuse doesn't have power and according to the "fuse map" print on the side kick pannel, it's labeled it's for the mirror and heating fuse?
so now i just want to know where should i start tracing. i dont' care about the foglight anymore. just want everything back to normal (i.e. no foglight = normal for me since i did the TSX HID retrofit). somebody please help. thanks much in advance.
